Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
How to use crypto-api-toolkit in SIM mode
das__batsayan
I am using https://github.com/intel/crypto-api-toolkit repo to learn PKCS#11, my current SGX_SDK version is 2.13 , on Ubuntu 18.04
I build the above using $ sh autogen.sh; $ ./configure; $ make SGX_MODE=SIM; $ sudo make install
Question : Does the repo supports SIM mode build? In the above build I did not face any error message.
Got following error when executing
$./p11test
76) test: UnsupportedAPITests::testWaitForSlotEvent (F) line: 120 TestsNoPINInitBase.cpp
setUp() failed
- equality assertion failed
- Expected: 0
- Actual : 48
77) test: UnsupportedAPITests::testGetFunctionStatus (F) line: 120 TestsNoPINInitBase.cpp
setUp() failed
- Expected: 0
- Actual : 48
78) test: UnsupportedAPITests::testCancelFunction (F) line: 120 TestsNoPINInitBase.cpp
setUp() failed
- Expected: 0
- Actual : 48
Also got this error
$pkcs11-tool --module /usr/local/lib/libp11sgx.so --init-token --label "ctk" --slot 0 --so-pin 1234 --init-pin --pin 1234
error: PKCS11 function C_Initialize failed: rv = CKR_DEVICE_ERROR (0x30)
Aborting.
Any help on what I am missing will be appreciated.
--Batsayan
Labels (2)
Sankar_V
In addition to the other file, please also make the below change in src/p11/untrusted/Makefile.am
HW:
-AM_LDFLAGS = -L$(SGXSSLDIR)/lib64 -lsgx_usgxssl -L$(SGXSDKDIR)/lib64 $(DCAP_LIB) -lsgx_urts -lsgx_uprotected_fs \
SIM:
+AM_LDFLAGS = -L$(SGXSSLDIR)/lib64 -lsgx_usgxssl -L$(SGXSDKDIR)/lib64 $(DCAP_LIB) -lsgx_urts_sim -lsgx_uae_service_sim -lsgx_uprotected_fs \
And, please also delete the /opt/intel/cryptoapitoolkit directory before you do a sudo make install. I just checked, and it worked.
JesusG_Intel
Hello Batsayan,
The Crypto API Toolkit for Intel SGX does not support Intel SGX Simulation mode. Refer to the Prerequisites section for a full list of system and software requirements to run the Crypto API Toolkit.
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello Batsayan,
I just received an update from engineering:
"Yes, Crypto API Toolkit will work in the simulation mode, but we have not explicitly enabled the Makefile for it (but we don’t test it). We have to make changes manually."
We will soon have a response for you on what needs to be done in the Makefile.
Sincerely,
Jesus G.
Sankar_V
You can make the below change to enable simulation mode runs:
In src/p11/trusted/Makefile.am
HW:
-m64 -Wall -O2 -D_FORTIFY_SOURCE=2 -Wl,--no-undefined -nostdlib -nodefaultlibs -nostartfiles -Wl,-z,noexecstack -Wl,-z,relro -Wl,-z,now -pie -L$(SGXSSLDIR)/lib64 -Wl,--whole-archive -lsgx_tsgxssl -Wl,--no-whole-archive -lsgx_tsgxssl_crypto -L$(SGXSDKDIR)/lib64 -Wl,--whole-archive -lsgx_trts -Wl,--no-whole-archive -Wl,--start-group -lsgx_tstdc -lsgx_tcxx -lsgx_tcrypto -lsgx_tservice -lsgx_tprotected_fs -Wl,--end-group -Wl,-Bstatic -Wl,-Bsymbolic -Wl,--no-undefined -Wl,-pie,-eenclave_entry -Wl,--export-dynamic -Wl,--defsym,__ImageBase=0 -Wpragmas -Wl,-soname -Wl,libp11SgxEnclave.so.0 -o .libs/libp11SgxEnclave.so.0.0.0
SIM:
-m64 -Wall -O2 -D_FORTIFY_SOURCE=2 -Wl,--no-undefined -nostdlib -nodefaultlibs -nostartfiles -Wl,-z,noexecstack -Wl,-z,relro -Wl,-z,now -pie -L$(SGXSSLDIR)/lib64 -Wl,--whole-archive -lsgx_tsgxssl -Wl,--no-whole-archive -lsgx_tsgxssl_crypto -L$(SGXSDKDIR)/lib64 -Wl,--whole-archive -lsgx_trts_sim -Wl,--no-whole-archive -Wl,--start-group -lsgx_tstdc -lsgx_tcxx -lsgx_tcrypto -lsgx_tservice_sim -lsgx_tprotected_fs -Wl,--end-group -Wl,-Bstatic -Wl,-Bsymbolic -Wl,--no-undefined -Wl,-pie,-eenclave_entry -Wl,--export-dynamic -Wl,--defsym,__ImageBase=0 -Wpragmas -Wl,-soname -Wl,libp11SgxEnclave.so.0 -o .libs/libp11SgxEnclave.so.0.0.0
das__batsayan
What I did
git clone https://github.com/intel/crypto-api-toolkit
cd crypto-api-toolkit
changed src/p11/trusted/Makefile.am for SIM as suggested above
sh autogen.sh
make SGX_MODE=SIM
sudo make install
cd src/test
./p11test
$ ./p11test
.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F
!!!FAILURES!!!
Test Results:
Run: 78 Failures: 78 Errors: 0
1) test: SymmetricAlgorithmTests::testAesEncryptDecrypt (F) line: 120 TestsNoPINInitBase.cpp
setUp() failed
- Expected: 0
- Actual : 48
2) test: SymmetricAlgorithmTests::testAesWrapUnwrap (F) line: 120 TestsNoPINInitBase.cpp
setUp() failed
- Expected: 0
- Actual : 48
JesusG_Intel
Hello Batsayan,
I reproduced your issue. Engineering is investigating this issue. We will respond to this thread as soon as we have an update.
Sincerely,
Jesus G.
Sankar_V
HW:
SIM:
das__batsayan
Thanks for quick reply, the SIM build issue is solved by the methods mentioned by you.
--Batsayan
JesusG_Intel
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
