Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
1559 Discussions
I cant use stdatomic.h inside enclave project
Medina_Chirinos__Jor
Hi there,
I need to use inside my enclave project the library stdatomic.h. I am getting: fatal error: stdatomic.h: No such file or directory. I am using
and I checked in the documentation the function should be ok inside the enclave.
does anybody know what the problem could be?
Hoang_N_Intel
Is your project for C code only? For the standard sample projects, you should be able to include the C++ atomic header without any issue such as
#include <atomic>
Hi Hoang,
My project is for C code only
Hi Hoang,
Why I cant use the stdatomic.h in my C project and the documentation says that is ok? what do you suggest me to do?
