Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Intel DCAP - PCKIDRetrievalTool SGXError:200f
ChrisCode
for a project I am working with DCAP attestation.
As a starting point I want to run the QuoteGenerationSample from the sample code on Github so I followed the DCAP Quick Install Guide. However when I try to run the PCKIDRetrievalTool it returns the following error:
Intel(R) Software Guard Extensions PCK Cert ID Retrieval Tool Version 1.16.100.2
Warning: platform manifest is not available or current platform is not multi-package platform.
Error, call sgx_create_enclave: fail [load_enclave], SGXError:200f.
I can't get it to work. My testing environment is an Intel NUC with Ubuntu 22.04. and FLC support.
I installed the latest SGX SDK (sgx_linux_x64_sdk_2.19.100.3.bin) and PSW and the latest driver (sgx_linux_x64_driver_2.11.54c9c4c.bin).
Thanks in advance!
ChrisCode
I found the issue. I had installed the old version of the PCKIDRetrievalTool.
My bad!
ChrisCode
My bad!
KFPW_Intel
Hi ChrisCode,
This is amazing! I am glad to hear that the issue was solved.
This thread will be marked as answered and Intel will no longer monitor this thread. I saw another thread created, lets move our discussion there. Thank you.
Ken
