Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Intel SGX Pthreads
PYuhala
The latest Intel SGX developer Reference for Linux* OS (version 2.12) specifies (from page 137) APIs provided by the SGX pthread library. However there is not any example Sample code that uses or shows how to use these APIs in SGX applications. More specifically, what are the associated header files to import, EDL files etc.
I have tried using the API (pthread_create(...) etc) after adding "-lsgx_pthread" in my link options, but this alone does not seem to be enough; the said routines are not found by my compiler.
JesusG_Intel
Hello PYuhala,
In addition to adding -lsgx_pthread to your link statement in the Makefile, you must...
  1. Copy sgxsdk/include/sgx_pthread.edl to your Enclave source directory.
  2. In Enclave.edl, add: from "sgx_pthread.edl" import *;
  3. In Enclave.cpp, add: #include "pthread.h"
JesusG_Intel
Hello PYuhala,
PYuhala
Thank you for your response. Will do as you have said.
JesusG_Intel
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
