Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Intel Software guard extensions activation app
LuX1o
i activate with the app and now i cant disable it
no SGX in bios
thanks
Sahira_Intel
SGX implementation in the BIOS is OEM independent. Please contact your PC manufacturer for guidance on SGX settings in the BIOS.
Sincerely,
Sahira
Sahira_Intel
Just to clarify, are you using the Intel SGX Activation App? What is the output from the SGX Activation App?
Did you check the Security tab in BIOS? If Intel SGX is not exposed in the BIOS then the App cannot activate it. If SGX was successfully enabled by the app, then check that Device Manager | System devices and Software Components list Intel® Software Guard Extensions.
Sincerely,
Sahira
Sahira_Intel
Do you still require assistance with this issue?
Sincerely,
Sahira
LuX1o
yes.
i use the activation app
and i activate with it sgx
but in bios gigabyte bki7ha7500 there is no option called gsx to disable it now
Sahira_Intel
Sincerely,
Sahira
Sahira_Intel
This case is closed and Intel is no longer monitoring this thread. Please open a new case for further questions.
