Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Intel sgx generate public key using ecdsa algo
AnaJavine
sgx_ecc256_create_key_pair(&p_private, &p_pub
sgx_ecc256_create_key_pair(&p_private, &p_public, ctx);
I am trying to generate a ecdsa keypair but getting uint8_t instead of public key .
How can i actually get the generated public key?
JesusG_Intel
Hello AnaJavine,
To help us assess your issue, please provide your code before you call the function sgx_ecc256_create_key_pair.
JesusG_Intel
Hello AnaJavine,
Do you still need help with this issue?
JesusG_Intel
Intel is no longer monitoring this thread. If you want a response from Intel in a follow-up question, please open a new thread.
