Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Intel-sgx
jet_li_ofchina
The program running in an enclave based on Intel SGX—the process of data intersection between parties A and B—does it have a solution where data can be output in plaintext to the log? Based on the ccoo case, the cross_lang_framework case, the data running in the program can be output in plaintext to the console. In this way, if the SGX environment is on A's machine, can A output the data obtained from B outside the enclave?
Vipin_S_Intel
Hi Jet, we would like to inform you that we are routing your query to the dedicated team for further assistance.
