Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Invoking edger8r manually
AArya2
I enter something like this in the windows command line:
sgx_edger8r.exe --use-prefix --search-path "C:\Program Files (x86)\Intel\IntelSGXSDK\include\" --trusted-dir C:\Users\Arya\Desktop\Enc --untrusted-dir C:\Users\Arya\Desktop\App --use-prefix C:\Users\Arya\Desktop\Enc\End.edl
And edger8r rejects it, displaying its "help" page, indicating that it believes the input is not formatted correctly. How come?
Anusha_K_Intel
Please check it is a syntax mistake probably. When the syntax of the command is not correct it displays the help page.
AArya2
Well that's obviously the case, my question is how.
Anusha_K_Intel
I have tried  executing the same command,I had the same error but after removing the double quotes after the --search-path it worked for me.Try using the below command:
sgx_edger8r.exe --use-prefix --search-path C:\Program Files (x86)\Intel\IntelSGXSDK\include\ --trusted-dir C:\Users\Arya\Desktop\Enc --untrusted-dir C:\Users\Arya\Desktop\App --use-prefix C:\Users\Arya\Desktop\Enc\End.edl
