Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1546 Discussions
Is it possible to perform curve operations directly in SGX?
Terry_Chen
Hi community!
sgx_tcypto provides many cryptographic primitives. But what if I just want to directly perform some curve operations like ECadd or point multiplication in enclave?
They should be basic operations in those cryptographic primitives, but not included in sgx_tcypto.h.
Sahira_Intel
Hi Terry,
Apologies for the late response. The cryptographic primitives are not exposed by sgx_tcrypto.h but are supported by the IPP Crypto library, so they can be used within an enclave.
This might be useful to you: https://www.intel.com/content/www/us/en/develop/documentation/ipp-crypto-reference/top/public-key-cryptography-functions/elliptic-curve-cryptography-functions/arithmetic-of-the-group-of-elliptic-curve-points.html
Sincerely,
Sahira
Sahira_Intel
Hi Terry,
Sincerely,
Sahira
ElioB
Hi @Terry_Chen thank you for the post.
I am not a domain expert, however, I have a few suggestions. I have encountered the same issue while working for a leading ai development services provider. If you are really looking for specific elliptic curve operations like ECadd or point multiplication and can't find these operations readily available, you have few options,
Either go for custom implementation, where you can implement them manually within the GSX enclave.
Or depend on external libraries
Or look for documentation and forums & communities
