My goal is to inject some extensions into the enclave application during initialization to transparently execute the runtime analysis strategy, like libos dose.
I recently searched for analysis tools for enclave programs, but most tools have their own simulators, like triton and angr. Then I found this document (332680-001-720907.pdf ), which mentioned that the side channel detection tool uses Intel Pin. But it also emphasizes that it is only SGX simulation mode.
Is there a way to run an analysis tool such as pintool in an SGX enclave? Maybe using libos is a good way to let Intel Pin run on libos, but it seems too heavy.
Hi Rlyown,
Let me check with relevant team and I'll update here at the earliest.
Wan
Hello Rlyown,
We've received feedback from relevant team.
Running Intel® Pintool would have to be done, but in either SDK simulation mode or inside an Enclave within a Library OS (Gramine), even though, as you pointed out is very heavy. There is not really another way that we know of.
Sorry for the inconvenience and thank you for your support.
Wan
Hi Rlyown,
Thanks for your question.
If you need additional information from Intel, please submit a new question as this thread will no longer be monitored.
Wan
