Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1545 Discussions
Is there any way how to place IPSec endpoint inside enclave
Rama__Klei
I am trying to find some sgx projects which try to place IPSec endpoint inside enclave but I could not find any one. As for that reason I was wondering if such thing is possible at all? I wanted to use StrongSwan to setup an IPSec tunnel between server and client's enclave but the IPSec endpoint to client machine is at IP layer so my packets got decrypted before they go to enclave which is in Application Layer.
If such thing is possible I could appreciate any help which can give me a starting point
Merry Christmall to all
