Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Linux RemoteAttestation Sample code Failed
Changzheng_W_Intel
Hi
I build linux RemoteAttestation Sample code on a SGX enabled PC with cmd
make SGX_MODE=HW SGX_DEBUG=1
and run ./app, got the error outpur as below:
root@qat-sgx-pc:/opt/intel/sgxsdk/SampleCode/RemoteAttestation# ./app
Call sgx_create_enclave success.
Call enclave_init_ra success.
Error, call sgx_ra_get_msg1 fail [main].
Call enclave_ra_close success.
Enter a character before exit ...
I also ran other Sample code in SDK, such as SampleEnclave and LocalAttestation in HW mode, they are all OK.
My OS is ubuntu 14.04, and my network is Intel internal network.
If I configure the network proxy, it will hang at "Call sgx_create_enclave success." for a while then failed with above message.
If I disable the network proxy, it will immediately fail with above message.
Is there any configuration related to network for this RemoteAttestation sample code?
Changzheng_W_Intel
Fixed.
EPID Provisioning needs network access. Setting proxy in /etc/aesmd.conf as:
proxy type = manual
aesm proxy = proxy.host:port
Then restart aesmd service using "service aesmd restart"
By the way, the SGX (driver/psw/sdk) need to be upgraded to the latest 1.6 release (I used version 1.5 at the beginning and then get SGX_ERROR_UPDATE_NEEDED error), then the sample code works well
Changzheng_W_Intel
Fixed.
proxy type = manual
sz
Hi,Changzheng_W_Intel.
How can i set the proxy value?
and
Does the value is the EPID Provisioning service Host?
thanks ~
