Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1545 Discussions
My server socket2 only has 6 blocks, how can it become 8 blocks
shouheng
I have a server, but the memory is as follows, please can I meet the requirements of the following table, what should I do?
Iffa_Intel
before proceeding further, could you clarify:
  1. Your hardware informations (eg: Intel Xeon,CPU,GPU) and does this case has relation to another case that you raised previously?
  2. Your server documentation
  3. Your use case (eg: use SGX on a new Intel Xeon server)
Cordially,
Iffa
Iffa_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Cordially,
Iffa
