Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
OpenSSL with Intel SGX Enclave
Sam5
I am currently developing a Intel SGX Application. And I need to use OpenSSL library in the enclave. However, when I build the enclave, tons of errors appear. They looks like this:
Error   17  error C2061: syntax error : identifier 'FILE'   C:\OpenSSL-Win32\include\openssl\asn1.h 994 1   Enclave
Any help is appreciated.
-Thanks
Surenthar_S_Intel
Hi Sam,
Are you using the Intel trusted OpenSSL library? There is a sample code "X509 project" that shows how to use the trusted OpenSSL (topenssl) inside enclaves. If you want to use another version of OpenSSL you should build it with Intel trusted standard C/C++ libraries and create an "enclave library" then link it to the enclave. You can not link the enclave with some random libraries you only can link it with trusted static libraries.
Thanks and Reagrds,
Surenthar Selvaraj
Surenthar_S_Intel
Hi Sam,
You should probably either, Configure OpenSSL with no-stdio if you are not using it; or include <stdio.h> on Windows for FILE (or <unistd.h> on Linux)
Thanks and Reagrds,
Surenthar Selvaraj
Sam5
I am not sure if I configure the enclave correctly.
VC++ Directories   -->   Include Directories "C://OpenSSL-Win32/include"
                                      Library Directories "C://OpenSSL-Win32/lib"
C/C++                    -->   Additional Include Directories "(some SGX default); C://OpenSSL-Win32/include"
Linker                     -->  General  -->  Additional Library Directories "C://OpenSSL-Win32/lib"
                                      Input --> Additional Dependencies: "libeay32.lib; ssleay32.lib"
-Thanks
Surenthar_S_Intel
Hi Sam,
Thanks and Reagrds,
Surenthar Selvaraj
kalsheraut
wolfSSL is currently developing the wolfCrypt operations (SHA-256, AES-GCM and RSA Encrypt/Decrypt)
to work with SGX Enclave on an internal test bed. It is expected to be ready for the public in the near future!
The reason wolfSSL thought it relevant to reply to your question is:
wolfSSL footprints typically average between 80K and 120K. Footprints vary depending on
functionality and speed optimizations. wolfSSL expects to see similar footprints here. This is
preferential to OpenSSL footprint sizes.
Sam5
Yes, i am using the Intel trusted OpenSSL Lib.
shen_y_
I did not find the "X509 Project " in the SDK for Linux. Where is the topenssl library in SDK for Linux?
Juan_d_Intel
Have a look at IntelSGXSDK\src\X509Verifier
Svart_K_
 I know this thread is older, but is there a OpenSSL version for the Linux SDK already?
I just saw the release for WIndows here: https://software.intel.com/en-us/sgx-sdk/download
Juan_d_Intel
No, there is no OpenSSL for the Linux SDK.
Marcos_Vinicius_Mont
 What is the similar solution to openssl for sdk linux?
Surenthar_S_Intel
Thanks for your Query. We will update you soon.
-Surenthar
