Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Password of learning Zip file
Roshan_Mehta
Does anyone knows the password of zip file provided here:
https://software.intel.com/en-us/sgx/training
This is a learning material.
Rodolfo_S_
New Contributor III
I have just download both zip files available in that page, and was able to unzip them without providing any password (using unzip program on Ubuntu system).
Rodolfo
Roshan_Mehta
I don't know for me it asks for the password and if I do roshan@bolt:~$ unzip Intel-SGX-Web-Training-Labs.zip
The directories are created with nothing inside them.
Are you able to get the actual file with contents? If yes could you mail me to gmate.sunny@gmail.com
RDrag
I get the same result (empty folders) when decompressing here with unzip (both on Mac and on Linux).
root@razubuntu:~/sgxtrainig# unzip /media/sf_vmshare/Intel-SGX-Web-Training-files.zip
Archive:  /media/sf_vmshare/Intel-SGX-Web-Training-files.zip
   skipping: index.html              unsupported compression method 99
   skipping: Lab Manual v1.0.pdf     unsupported compression method 99
   skipping: Part 1/_notes/application_parts.png.mno  unsupported compression method 99
   skipping: Part 1/application_parts.png  unsupported compression method 99
   skipping: Part 1/application_parts_sm.png  unsupported compression method 99
   skipping: Part 1/Enclave.signed.dll  unsupported compression method 99
   skipping: Part 1/ImproperIntelSGXDetection.exe  unsupported compression method 99
   skipping: Part 1/NoIntelSGXDetection.exe  unsupported compression method 99
   skipping: Part 1/part1.html       unsupported compression method 99
   skipping: Part 1/ProperIntelSGXDetection.exe  unsupported compression method 99
   skipping: Part 2/part2.html       unsupported compression method 99
   skipping: Part 2/partitioning-sm.png  unsupported compression method 99
   skipping: Part 2/partitioning.png  unsupported compression method 99
   skipping: Part 3/file-encrypter-arch-1-sm.png  unsupported compression method 99
   skipping: Part 3/file-encrypter-arch-1.png  unsupported compression method 99
   skipping: Part 3/file-encrypter-arch-2-sm.png  unsupported compression method 99
   skipping: Part 3/file-encrypter-arch-2.png  unsupported compression method 99
   skipping: Part 3/part3.html       unsupported compression method 99
   skipping: Part 4/part4.html       unsupported compression method 99
   skipping: Part 5/part5.html       unsupported compression method 99
   skipping: Part 6/debux-mixed-sm.png  unsupported compression method 99
   skipping: Part 6/debux-mixed.png  unsupported compression method 99
   skipping: Part 6/part6.html       unsupported compression method 99
   skipping: Part 7/part7.html       unsupported compression method 99
   creating: Part 1/
   creating: Part 1/_notes/
   creating: Part 2/
   creating: Part 2/_notes/
   creating: Part 3/
   creating: Part 3/_notes/
   creating: Part 4/
   creating: Part 4/_notes/
   creating: Part 5/
   creating: Part 5/_notes/
   creating: Part 6/
   creating: Part 6/_notes/
   creating: Part 7/
   creating: Part 7/_notes/
When attempting to decompress with the latest 7zip, I get this
7-Zip 9.20  Copyright (c) 1999-2010 Igor Pavlov  2010-11-18
p7zip Version 9.20 (locale=en_US.UTF-8,Utf16=on,HugeFiles=on,2 CPUs)
Processing archive: /media/sf_vmshare/Intel-SGX-Web-Training-files.zip
Extracting  index.html
Enter password (will not be echoed) :
I tried the obvious passwords ("sgx", "intel", etc) but they didn't work :).
RDrag
It appears to unzip fine from Windows (using WinZip).
Roshan_Mehta
@Razvan:
No, it does not even on windows. Are you actually able to unzip and get the actual files with content?
See the attachment, unzip on windows also asks for the password. If you have actually obtained the files, could you send it to gmate.sunny@gmail.com
RDrag
Try to redownload the ZIP files, that's what I've just done here and with "WinZip 16.5 (10096) - 64-bit" it unzipped just fine (yes, the files, not just the structure). I'm not sure I'm allowed to relay the files but try to redownload them, they may have changed them recently.
Roshan_Mehta
Thanks, I think they have updated the zip file.
