Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Previous SGX SDK Version
Toffalini__Flavio
Hi Everybody,
I am looking for previous SDK for SGX.
I strolled around Intel Dev Zon but I didn't find anything.
Does somebody know whether and where it is possible to retrieve previous SDK version, please?
Thanks in advance,
Flavio!
Hoang_N_Intel
Is there a specific reason that you would like to use older version(s) of the SDK? How far back of older release are you looking for? If you look at the release note, the latest version(s) address a number of vulnerabilities and bug fixes, some of them that are important enough that you should consider to upgrade to, not going backward.
Toffalini__Flavio
Hi Nguyen!
I need them because I am a Ph.D. student who is making an academic research on SGX. I would verify my assumptions over previous SGX SDKs.
As I said, my interests are purely academic, i.e., I will just write a paper about.
Do you think it is possible to get previous SDKs version, please?
It would be very useful to me.
Rodolfo_S_
New Contributor III
Hi, Flavio.
Did you take a look at 01.org? Here you can find older versions of the SDK.
Good luck on your research!
Rodolfo
Toffalini__Flavio
Hi Rodolfo,
Thanks, that's really cool for Linux!
Anything similar for Windows as far as you know?
Cheers,
Flavio
