Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Question about SGX support Server
Sam5
I need to know SGX only support Desktop/Laptop? it doesn't support Server like workstation?
Sam
Surenthar_S_Intel
Hi Sam,
SGX Support Desktop, Laptop and Server like workstation.
I will ensure that the Z240 has one of these supported chipsets. SGX was enabled on Z240 with BIOS 1.07. This was the first Refresh BIOS in January 2016.”
  • Intel Xeon E3-1225v5 3.3 GHz (up to 3.7 GHz) 8MB GT2 4C 80W TWR CPU
  • Intel Xeon E3-1230v5 3.4 GHz (up to 3.8 GHz) 8MB GT0 4C 80W TWR CPU
  • Intel Xeon E3-1240v5 3.5 GHz (up to 3.9 GHz) 8MB GT0 4C 80W TWR CPU
  • Intel Xeon E3-1245v5 3.5 GHz (up to 3.9 GHz) 8MB GT2 4C 80W TWR CPU
  • Intel Xeon E3-1270v5 3.6 GHz (up to 4.0 GHz) 8MB GT0 4C 80W TWR CPU
  • Intel Xeon E3-1280v5 3.7 GHz (up to 4.0 GHz) 8MB GT0 4C 80W TWR CPU
Thanks and Regards,
Surenthar Selvaraj
Surenthar_S_Intel
Hi Sam,
Thanks and Regards,
Surenthar Selvaraj
Sam5
Thanks Surenthar.
Debakanta_S_
Hi Surenthar,
We tried installing Intel SGX on out new NUC i76700U machine but failed.
We are planning to procure another NUC machine.
We need the hardware and software specifications so that it will be possible to install Intel SGX.
Can you please suggest especially which processor should we take for installing.
Thanks & Regards,
Debakanta
Surenthar_S_Intel
OEM Name:        Intel NUC Mini PC kit
Model :                NUC6I5SYH/ NUC6I5SYK/ NUC6I3SYH/ NUC6I3SYH
-Surenthar
Ofir_W_
Hi Surenthar,
Do these machines ( NUC6I5SYH/ NUC6I5SYK/ NUC6I3SYH/ NUC6I3SYH) come with a BIOS that supports SGX?
Do they support SGX 2?
Can BIOS update upgrade an existing system with SGX 1 to support SGX 2?
Thanks!
Ofir
Surenthar_S_Intel
Yes, The Intel SGX driver is required if SGX security is enabled in BIOS. Download the Driver from link "https://downloadcenter.intel.com/download/26137/Intel-Software-Guard-Extensions-Software-for-Intel-NUC"
No. Currently it support SGX version 1
Currently SGX version 1 is available to use.  will let you know when there is update on SGX version 2
-Surenthar
tyler_l_
-Surenthar
Hi Surenthar, I found the SGX Driver from the given link ("https://downloadcenter.intel.com/download/26137/Intel-Software-Guard-Extensions-Software-for-Intel-NUC") is only for Windows. Is there Linux version for NUC6I5SYH/ NUC6I5SYK/ NUC6I3SYH/ NUC6I3SYK? If not, can I use the driver from link "https://github.com/01org/linux-sgx-driver"?
Surenthar_S_Intel
SGX driver is OEM independent, so yes you should be able to use the one on Github for any SGX supported system. Only requirement in Linux is that you will need to use Ubuntu 14.04 LTS for OS. Hope that helps.
-Surenthar
