Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Remote attestation System requirement
Roshan_Mehta
To use remote attestation, do both client(thin machine) and server(computations system, 3rd party) needs to be SGX enabled machine? or only the server can be SGX enabled machine. I wanted to provision secret key from client to the server. As server enclave code can be disassembled.
I am planning to use thin clients to talk to the big server.
Rodolfo_S_
New Contributor III
Hi, Only the part being attested (the server in this case) needs to be SGX enabled. Best regards, Rodolfo
Rodolfo_S_
New Contributor III
