Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
SGX  AESM Service
JChen207
I  wish  to  create  a  SGX  platform in windows  and  now  I  install  all  app  of  the  SGX(Intel SGX SDK for Windows,PSW,SgxPlatformCapabilityTool....and so on).
But  when  I  install  done, it says "Intel(R) SGX is currently disabled.
Contact your computer manufacturer to see if SGX is supported on your platform."
while  CLICK  the  "SgxPlatformCapabilityTool" .
I  check  the  computer  event  to  make  sure  what  happen  is .
It  says   "AESMService: SGX is Disabled at AESM Service startup "
I  find  all  the  way  from  Google  but  I  can't  find  out
Has anyone done this with or without issues?
Thanks  a  lot .
Surenthar_S_Intel
First Uninstall the SGX Driver and SGX related components, restart and install once again.
Please share your system configuration with us. will check and let you know.
-Surenthar
JChen207
Hi  Selvaraj ,
I  tried  the  way  from  yours .
But  I  still  can't  enable  the  SGX  successfully.
What  is  your  meaning  of  my  system  configuration ?
Do  you  mean  my  PC  equipment ?
My  PC  equipment  as  below :
CPU : Intel  i3 - 7100
MB : ASUS  H110M - K
Thanks  a  lot .
Lipin__Stas
Helo. Constant critical error AESMService: SGX is Disabled at AESM Service startup.
Jonker__Tiaan
Same problem here....
