Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
SGX Application Deployment
Rad_A_
I just wrote a simple console application to test if the machine has SGX feature (by calling sgx_is_capable function), and if so, to try to enable it programmatically (by calling sgx_enable_device function). Note that the application is not an enclave and does not use an enclave either. It works perfectly on my machine (which has SGX feature, as well as both VS2012 and SGX SDK installed). Now my question is how to deploy it on client's machine. What dependencies does the application need to execute? I cannot get it running by just copy and paste (error 0xc00007b). Thanks in advance.
Francisco_C_Intel
sgx_enable_device() requires the platform software installed on the device.
sgx_cap_enable_device() does not have this requirement, but does require the sgx_capable.dll to be present as well as admin privileges.
Francisco_C_Intel
Rad_A_
Got it. Thanks Francisco.
