Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
SGX_ERROR_SERVICE_INVALID_PRIVILEGE error
Rashmik
Have a simple java application that uses SGX to fetch key, encrypt decrypt bytes.  Upon running the jar, I run into SGX_ERROR_SERVICE_INVALID_PRIVILEGE error.
Have the user as part of sgx_prv group and have run application as root as well, still get the same error.
The server uses in-kernel driver.
Weird thing is that the same functionality provide by my sample Golang application works without any error.
Labels (5)
Iffa_Intel
It's recommended to install the Out-Of-Tree Driver.
The OOT Driver is recommended for use on platforms that do not support or are not configured for Flexible Launch Control.
You may refer to this documentation (Out-Of-Tree Driver section) for further details.
Cordially,
Iffa
Iffa_Intel
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
