Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
SGX_ERROR_UNEXPECTED
Wang__Huibo
When I am calling
sgx_ecc256_create_key_pair,
I got the following error.
The key creation process failed due to an internal cryptography library failure.
Does anybody run into this error before? Or Does anybody have the answer for this error.? Thank you in advance!
JC1
I don't know if it's related but I have the same error when trying to use sgx_sha256_update.
I call sgx_sha256_init first which returns successfully but then calling sgx_sha256_update returns SGX_ERROR_UNEXPECTED.
I'd be interested to know if you got this working or if someone else has found the answer.
Wang__Huibo
Hi I fixed my error because of invalid input, so Please check your inputs again.
JC1
Thanks for your reply. I'll check.
tianyu_l_
hello Huibo,
I am glad to communicate with you.
I hope that you can tell me which motherboard  you use in your computer, and I also hope to get touch with you.
so could you tell me what is your facebook number or weixin number.
sincerely,
Tianyu Li
