Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
SGX SDK for Windows 11
mchau
I'm trying to install the SGX SDK, but after I run the .exe file nothing happens after the green progress bar. I'm on Windows 11. Is this a compatibility issue and the SGX SDK is not yet supported for Windows 11?
Sahira_Intel
The SGX SDK is supported on Windows 11, see system requirements below:
Supported operating systems for the Intel® SGX SDK installer:
o Microsoft Windows* 7 64-bit version
o Microsoft Windows* 10 November Update (version 1511) or later, including
versions 1607, 1703, 1709, 1803, 1809, 1903 and 2004
o Microsoft Windows* 11
Supported compiler and IDE for the Intel® SGX SDK installer:
o Microsoft Visual Studio* Professional 2019
Microsoft Visual C++ compiler from Microsoft Visual Studio* Professional 2019
is required
There are some known issues while installing on systems with Visual Studio 2022. I recommend removing all instances of the SDK off your system and try to re install. This time, download the latest SGX SDK from Nuget.org: https://www.nuget.org/packages/Intel.SGX.SDK
Let me know if you have any questions
Sincerely,
Sahira
Sahira_Intel
is required
Sincerely,
Sahira
