Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
SGX deosnt work inside Docker
alche
Hi, I'm trying to run enclave inside the Docker container using instruction from readme:
https://github.com/intel/linux-sgx/blob/main/docker/build/README.md
Versions:
OS: Ubuntu 22.04.5 LTS
Kernel: 5.15.0-140-generic
Docker version 28.2.1, build 879ac3f
Docker Compose version v2.36.2
Everything works fine outside the Docker, enclaves generate quotes successfully: software is installed, platform is registered, PCCS servece works. But Docker doesn't.
I cloned linux-sgx repo, branch main,
commit 7385e10ce1106215d15f874a024ca224c7417eea
Did
make preparation
cd docker/build/
nano build_compose_run.sh #(replaced "docker-compose" with "docker compose" in the bottom line)
./build_compose_run.sh
It outputs
aesmd-socket
TRAC[0000] Docker Desktop integration not enabled
WARN[0000] /home/sgx_machine/linux-sgx/docker/build/docker-compose.yml: the attribute `version` is obsolete, it will be ignored, please remove it to avoid potential confusion
[+] Running 3/3
✔ Network build_default Created 0.1s
✔ Container build-aesm-1 Created 0.0s
✔ Container build-sample-1 Created 0.0s
Attaching to aesm-1, sample-1
aesm-1 | The path of system bundle: System Bundle
aesm-1 | ecdsa_quote_service_bundle_name:2.0.0
aesm-1 | epid_quote_service_bundle_name:2.0.0
aesm-1 | le_launch_service_bundle_name:2.0.0
aesm-1 | linux_network_service_bundle_name:2.0.0
aesm-1 | pce_service_bundle_name:2.0.0
aesm-1 | quote_ex_service_bundle_name:2.0.0
aesm-1 | system_bundle:4.0.0
aesm-1 | aesm_service[7]: [get_qpl_handle ../qe_logic.cpp:294] Cannot open Quote Provider Library libdcap_quoteprov.so.1 and libdcap_quoteprov.so
aesm-1 |
aesm-1 | aesm_service[7]: The server sock is 0x55dfeaed3d80
sample-1 | [get_driver_type edmm_utility.cpp:116] Failed to open Intel SGX device.
sample-1 | [get_driver_type /linux-sgx/psw/urts/linux/edmm_utility.cpp:116] Failed to open Intel SGX device.
sample-1 | Info: Please make sure SGX module is enabled in the BIOS, and install SGX driver afterwards.
sample-1 | Error: Invalid SGX device.
sample-1 | Enter a character before exit ...
DEBU[0005] otel error error="<nil>"
Is it a bug? I used main branch and there are literally two lines of code, there is nothing I could do wrong.
