Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
SGX launch enclave
gu_j_1
How does SGX windows SDK launch an enclave?
I think it will first launch the Launch Enclave with le.signed.dll, and then use this Launch Enclave to launch other enclaves. Is this right?
When I use sgx_create_enclave interface with le.signed.dll, the return value(error number) is 0x2001. So, how to launch the Launch Enclave?
Thanks in advance!
Surenthar_S_Intel
Update:
Intel SGX SDK for Linux* OS open source project is now live at:  https://01.org/intel-softwareguard-eXtensions
Dan_Zimmerman
Hi Gu,
There is no need to load the launch enclave directly.  The SGX Platform Software (PSW) handles that for you when the "Intel SGX AESM" service loads during Windows boot.  If you are having trouble loading your built enclave with sgx_create_enclave(), check that you have installed the PSW  and the "Intel SGX AESM" service is running.
cheers,
Dan
gu_j_1
Hi Dan,
Do you mean that the launch enclave is alive from windows' start up to shutdown?
Can I do some ecalls to it? That's to say, how to know it's enclave id and how to know it's interface.
I am very interesting about it. Thanks a lot!
Derek_B_Intel
Hi Gu,
As Dan mentioned the Intel SGX AESM service is started during Windows boot and should persist until shutdown.
The "Untrusted Library Functions" and "Trusted Libraries - > Platform Services Functions" sections of the SDK Users Guide include the public interface functions supported by the AESM service.
In addition, the Sample Applications demonstrate the use of these services.
Pete_M_
Dan and Derek,  are you aware of how developers can handle the Launch Enclave in Linux?
Surenthar_S_Intel
Currently, there is no publicly available version of a SGX SDK for Linux.  Stay tuned for more information coming in late Q2/Q3 timeframe.
Surenthar_S_Intel
Update:
