Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
SGX
thespecialist
Hi
I completed the requisite for kubeflow pipeline run on the azure However i could not see sgx plugin to the nodepool that i created
I am sure that i used the correct sku mentioned in the hands on session attached are the images
Moreover the python3 bcrypt is not working as expected passlib.exc.MissingBackendError: bcrypt: no backends available -- recommend you install one (e.g. 'pip install bcrypt')
Though i had installed mant times using pip and python  but still getting the same error INTEL-NODEPOOL-D4S-v3.png INTEL-NODEPOOL-D4S-v3.pngScreenshot 2024-01-28 at 3.46.45 PM.pngScreenshot 2024-01-28 at 3.46.45 PM.png
Zulkifli_Intel
Hi thespecialist,
Greetings to you.
Are you using the Intel Developer cloud? If yes please share with us your system details.
Zulkifli
thespecialist
Hi Zulkifli
the KubeFlow PoC is on Azure AKS environment, I had created the AKS and Nodepool, unfortunately, the Pods do not show the SGX plugin, at this point, I am not sure why the node pool is not showing DC4S_v3 SGX plugging
Let me know if anything I can provide
Wojciech_M_Intel
Hi thespecialist,
Dc4s_v3 definitely support SGX on Azure as its even used for the example here
https://learn.microsoft.com/en-us/azure/confidential-computing/confidential-enclave-nodes-aks-get-started
Apologies but I'm not familiar with the hands on session that you had.
Have you tried to contact the person that was conducting the hands on?
For more information and support for SGX Plugin please use https://github.com/intel/intel-device-plugins-for-kubernetes?tab=readme-ov-file#sgx-device-plugin
Wojtek
thespecialist
Thanks for your reply,  I was able to move forward with the session,
I had a few glitches in the encryption as Python was outdated, but I managed to encrypt it.
 i was able to install kubeflow & kustomize but unable to get external IP
Can you please help me with how do I get to contact the person that was conducting the hands-on?
thespecialist
Intel SGX Confidential computes running ML workload on the Azure,  can someone help me out here
thespecialist
the kubeflow dashboard does not open at all,
Screenshot 2024-02-25 at 8.57.27 PM.pngScreenshot 2024-02-25 at 8.57.27 PM.png
Sreelakshmi1
Hello thespecialist,
Good day!
We apologize for the delay in response caused.
Please note the query reported is about Azure support as the environment configuration for SGX is based on Azure Infra.
Please note about the contact person on conducting the hands-on, we do not have access to this information and we request to review the same with the training provider.
Sreelakshmi B
Sreelakshmi1
Hello thespecialist ,
Good day!
We are following up to find out if you were able to find the information we provided. Please reply to confirm, so we can continue helping on a resolution. Looking forward to receiving your reply.
Sreelakshmi
Sreelakshmi1
Greetings for the day!
 We would like to inform you that we are closing this request as no response has been received from our previous follow-ups.
Please don't hesitate to ask any further questions in the future. Feel free to start a new conversation, as this thread will no longer be monitored.
Sreelakshmi
