Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Simulator for Intel SGX application.
joshi__vikram
I am runnning an application in simulator mode but its not working.
I am running github application.Her is the link:
https://github.com/intel/linux-sgx/tree/master/SampleCode/LocalAttestation
but It is giving error :
[_EINIT u_instructions.cpp:127] SECS attributes does NOT match launch token attribuets
[build_image /root/sgx/linux-sgx-master/psw/urts/loader.cpp:521] init_enclave failed
Load Enclave Failure
Available Enclaves
Enclave1 - EnclaveID 0
Enclave2 - EnclaveID 0
[remove_enclave /root/sgx/linux-sgx-master/psw/urts/enclave.cpp:684] remove an unknown enclave
Enclave3 - EnclaveID 0Enclave1_test_create_session Ecall failed: Error code is 2002
