Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Some OwnerEpoch questions
Alon_J_
I have a new Dell Inspiron 13 (7000 series).
  1. Where should I find the configure OwnerEpoch (OE) option? I can't find it anywhere in the BIOS menu.
  2. What is the current (default?) OE value, before the user configures it?
  3. Is this default OE value an SGX constant? Is it configured during manufacturing by Intel or by Dell?
  4. Is there any way for a running system to obtain the current OE value?
Kuppusamy_R_Intel
    Usually OEM's will not show all the BIOS information. Please contact Dell technical assistant team.
    Default OE Value is 128 bits
    Yes, configured in firmware during manufacturing by OEM's( Dell).
    The keys used for SGX enclaves are generated by the new instruction ‘EGETKEY’. The key is a combination of three factors (SGX Security Version Numbers, device ID and ‘Owner Epoch’)
Kuppusamy_R_Intel
