Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Test Intel Attestation Service has incorrect certificate
Rosłaniec__Piotr
Hello.
I just noticed that the certificate on https://test-as.sgx.trustedservices.intel.com domain is incorrect. It's issued for CN "dev-as.sgx.trustedservices.intel.com". The latter is also inaccessible.
Piotr
Elephant
I noticed this too!
Please fix this ASAP.  Thanks!
* Server certificate:
* 	 subject: C=US; postalCode=95054-1537; ST=California; L=Santa Clara; street=FM1-110; street=2200 Mission College Blvd; O=Intel Corporation; OU=Hosted by Intel Corporation; OU=Multi-Domain SSL; CN=dev-as.sgx.trustedservices.intel.com
* 	 start date: Jun  7 00:00:00 2019 GMT
* 	 expire date: Jun  6 23:59:59 2021 GMT
* 	 subjectAltName does not match test-as.sgx.trustedservices.intel.com
shi__webb
I'm calling the `get_sigrl_from_intel`  and it return the following error:
get_sigrl_from_intel tls.read_to_end: Custom { kind: InvalidData, error: WebPKIError(CertNotValidForName) }
Rosłaniec__Piotr
Turns out that the V2 attestation service has reached its end of life. You can learn about the new IAS below:
https://api.portal.trustedservices.intel.com/
https://api.trustedservices.intel.com/documents/sgx-attestation-api-spec.pdf
Update:
I'm not sure about the EOL, but the test IAS seems to have correct certificate now.
