Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1546 Discussions
The number that enclave can reside in memory simultaneously?
zhou__chen
I wonder how many enclaves can exist simultaneously.
I have read the developer reference, which says:
  • Depending on the memory footprint of each enclave, use cases suggest that 5-20 enclaves can reside in memory simultaneously.
Why? How the number 5-20 is calculated?
Is this true that the enclave number can be infinity as long as the memory is big enough?
Thank!!
Scott_R_Intel
Hi Chen.
There are quite a few other questions/discussions about SGX memory allocation, but the one below is probably best to help answer your question:
https://software.intel.com/en-us/forums/intel-software-guard-extensions-intel-sgx/topic/607004
Regards.
Scott
zhou__chen
Thank you very much!
