Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Unable to debug enclave in Visual Studio 2019
Edwardbr1
Hi I have my code debugging happily in visual studio 2017 in debug mode, but not in 2019.  I am using multibyte character sets, not wide utf16/UCS2 character sets.  I am compiling 64 bit with the /d2FH4- flag specified.  I can run the code fine, but I cannot hit any breakpoints in the enclave.
I am using visual studio 2019 16.9.3, against Intel SGX SDK for Windows v2.12.100.4. with the working directory of the executable set to $(OutDir).
Please note that the vcxproj files are generated from cmake files, this is so we can use ninja for our server side for faster builds and be able to target multiple OS's and compilers.
Edward
These are the typical compiler flags that I use in the untrusted executable, with some company include paths and libs stripped out for brevity:
/MP /ifcOutput "foo_test.dir\Debug\" /GS /Zc:rvalueCast /W3 /Gy /Zc:wchar_t /I"C:\PROGRA~2\Intel\INTELS~1\include" /I"C:\Dev\Secretarium\core1\cmakeconfigs\submodules\mbedtls\include" /I"C:\.hunter\_Base\36e7f44\4a04064\f9d8bc8\Install\include" /Zi /Gm- /Od /Ob0 /sdl /Fd"C:\Dev\Secretarium\core1\build\output\Debug\foo_test.pdb" /Zc:inline /fp:precise /D "ENCLAVE_STATUS=sgx_status_t" /D "ENCLAVE_OK=SGX_SUCCESS" /D "_LIB" /D "NOMINMAX" /D "WIN32" /D "_WINDOWS" /D "_DEBUG" /D "FMT_HEADER_ONLY=1" /D "SPDLOG_COMPILED_LIB" /D "SPDLOG_FMT_EXTERNAL" /D "FMT_LOCALE" /D "NNG_HAVE_BUS0" /D "NNG_HAVE_PAIR0" /D "NNG_HAVE_PAIR1" /D "NNG_HAVE_PUSH0" /D "NNG_HAVE_PULL0" /D "NNG_HAVE_PUB0" /D "NNG_HAVE_SUB0" /D "NNG_HAVE_REQ0" /D "NNG_HAVE_REP0" /D "NNG_HAVE_SURVEYOR0" /D "NNG_HAVE_RESPONDENT0" /D "NNG_TRANSPORT_INPROC" /D "NNG_TRANSPORT_IPC" /D "NNG_TRANSPORT_TCP" /D "NNG_TRANSPORT_TLS" /D "NNG_STATIC_LIB" /D "CMAKE_INTDIR=\"Debug\"" /D "_MBCS" /errorReport:prompt /WX /Zc:forScope /RTC1 /Gd /MDd /std:c++17 /FC /Fa"foo_test.dir\Debug\" /EHsc /nologo /Fo"foo_test.dir\Debug\" /Fp"foo_test.dir\Debug\foo_test.pch" /diagnostics:classic /bigobj
These are the linker flags that I use in the untrusted executable:
/OUT:"C:\Dev\Secretarium\core1\build\output\Debug\foo_test.exe" /MANIFEST /NXCOMPAT /PDB:"C:/Dev/Secretarium/core1/build/output/Debug/foo_test.pdb" /DYNAMICBASE "..\..\..\..\output\Debug\miscellaneous_host.lib" "C:\.hunter\_Base\36e7f44\4a04064\f9d8bc8\Install\lib\spdlogd.lib" "ws2_32.lib" /IMPLIB:"C:/Dev/Secretarium/core1/build/output/Debug/foo_test.lib" /DEBUG /MACHINE:X64 /WX /INCREMENTAL /PGD:"C:\Dev\Secretarium\core1\build\output\Debug\foo_test.pgd" /SUBSYSTEM:CONSOLE /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /ManifestFile:"foo_test.dir\Debug\foo_test.exe.intermediate.manifest" /LTCGOUT:"foo_test.dir\Debug\foo_test.iobj" /ERRORREPORT:PROMPT /NOLOGO /LIBPATH:"C:/PROGRA~2/Intel/INTELS~1/bin/x64/Release" /LIBPATH:"C:/PROGRA~2/Intel/INTELS~1/bin/x64/Release/Debug" /TLBID:1 /machine:x64 /IGNORE:4099 /IGNORE:4098 /IGNORE:4204
The enclave compile flags:
/MP /ifcOutput "foo_enclave.dir\Debug\" /GS /Zc:rvalueCast /W3 /Gy /Zc:wchar_t /I"C:\PROGRA~2\Intel\INTELS~1\include" /I"C:\Dev\Secretarium\core1\build\secretarium\libraries\foo\enclave" /I"C:\.hunter\_Base\36e7f44\4a04064\f9d8bc8\Install\include" /Qspectre /Zi /Gm- /Od /Ob0 /sdl /Fd"C:\Dev\Secretarium\core1\build\output\Debug\foo_enclave.pdb" /Zc:inline /fp:precise /D "ENCLAVE_STATUS=sgx_status_t" /D "ENCLAVE_OK=SGX_SUCCESS" /D "_LIB" /D "NOMINMAX" /D "_IN_ENCLAVE" /D "VERBOSE=2" /D "_DEBUG" /D "ALL_APPS_EMBEDDED" /D "IGNORE_DISTRIBUTION_INCONSITENCIES" /D "CMAKE_INTDIR=\"Debug\"" /D "foo_enclave_EXPORTS" /D "_WINDLL" /D "_MBCS" /errorReport:prompt /WX /Zc:forScope /Gd /MDd /std:c++17 /FC /Fa"foo_enclave.dir\Debug\" /EHsc /nologo /Fo"foo_enclave.dir\Debug\" /Fp"foo_enclave.dir\Debug\foo_enclave.pch" /diagnostics:classic /bigobj /d2FH4-
The enclave linker flags:
/OUT:"C:\Dev\Secretarium\core1\build\output\Debug\foo_enclave.dll" /MANIFEST /NOENTRY /NXCOMPAT /PDB:"C:/Dev/Secretarium/core1/build/output/Debug/foo_enclave.pdb" /DYNAMICBASE "sgx_tcxx.lib" "sgx_trts.lib" "sgx_tstdc.lib" "sgx_tservice.lib" "sgx_tcrypto.lib" /IMPLIB:"C:/Dev/Secretarium/core1/build/output/Debug/foo_enclave.lib" /DEBUG /DLL /MACHINE:X64 /WX /OPT:REF /INCREMENTAL:NO /PGD:"C:\Dev\Secretarium\core1\build\output\Debug\foo_enclave.pgd" /SUBSYSTEM:CONSOLE /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /ManifestFile:"foo_enclave.dir\Debug\foo_enclave.dll.intermediate.manifest" /LTCGOUT:"foo_enclave.dir\Debug\foo_enclave.iobj" /OPT:ICF /ERRORREPORT:PROMPT /NOLOGO /LIBPATH:"C:/PROGRA~2/Intel/INTELS~1/bin/x64/Release" /LIBPATH:"C:/PROGRA~2/Intel/INTELS~1/bin/x64/Release/Debug" /NODEFAULTLIB /TLBID:1 /machine:x64 /IGNORE:4099
JesusG_Intel
Hello Edward,
Was the information I provided helpful?
The Intel SGX SDK Developer Reference Guide for Windows that is distributed with each SDK contains the latest guidance in Section Setting up an Intel Software Guard Extensions Project. The guide is in the documents directory where you expanded the SGX SDK installer file. This slightly older Developer Reference Guide has the same guidance, I think.
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello Edward, here are the flags that work for me in Visual Studio 2019, 64-bit, SGX SDK 2.12.100.4
Enclave
C/C++ Command Line:
/ifcOutput "x64\Debug\" /GS /W4 /Zc:wchar_t /I"C:\git\src\SampleEnclave - Copy\\Include" /I"C:\Program Files (x86)\Intel\IntelSGXSDK\include" /I"C:\Program Files (x86)\Intel\IntelSGXSDK\include\tlibc" /I"C:\Program Files (x86)\Intel\IntelSGXSDK\include\libc++" /I"C:\Program Files (x86)\Intel\IntelSGXSDK\include\epid" /I"C:\git\src\SampleEnclave - Copy\\Enclave" /Qspectre /guard:cf /Zi /Gm- /Od /Fd"x64\Debug\vc142.pdb" /Zc:inline /fp:precise /D "_WINDLL" /errorReport:prompt /WX /Zc:forScope /Gd /MTd /FC /Fa"x64\Debug\" /EHsc /nologo /Fo"x64\Debug\" /Fp"x64\Debug\Enclave.pch" /diagnostics:column
Additional Options: /d2FH4-
Linker Command Line:
/OUT:"C:\git\src\SampleEnclave - Copy\x64\Debug\Enclave.dll" /MANIFEST:NO /NOENTRY /NXCOMPAT /PDB:"C:\git\src\SampleEnclave - Copy\x64\Debug\Enclave.pdb" /DYNAMICBASE "sgx_trts.lib" "sgx_tstdc.lib" "sgx_tservice.lib" "sgx_tcxx.lib" "sgx_tcrypto.lib" /IMPLIB:"C:\git\src\SampleEnclave - Copy\x64\Debug\Enclave.lib" /DEBUG /DLL /MACHINE:X64 /WX /PGD:"C:\git\src\SampleEnclave - Copy\x64\Debug\Enclave.pgd" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /ManifestFile:"x64\Debug\Enclave.dll.intermediate.manifest" /ERRORREPORT:PROMPT /NOLOGO /LIBPATH:"C:\Program Files (x86)\Intel\IntelSGXSDK\bin\x64\Debug" /NODEFAULTLIB /TLBID:1
Untrusted App
C/C++ Command Line:
/JMC /ifcOutput "x64\Debug\" /GS /W4 /Zc:wchar_t /I"C:\Program Files (x86)\Intel\IntelSGXSDK\\include" /I"C:\git\src\SampleEnclave - Copy\\Include" /I"C:\Program Files (x86)\Intel\IntelSGXSDK\\include\epid" /I"C:\git\src\SampleEnclave - Copy\\App" /guard:cf /Zi /Gm- /Od /Fd"x64\Debug\vc142.pdb" /Zc:inline /fp:precise /D "_MBCS" /errorReport:prompt /WX /Zc:forScope /RTC1 /Gd /MDd /FC /Fa"x64\Debug\" /EHsc /nologo /Fo"x64\Debug\" /Fp"x64\Debug\App.pch" /diagnostics:column
/OUT:"C:\git\src\SampleEnclave - Copy\x64\Debug\App.exe" /MANIFEST /NXCOMPAT /PDB:"C:\git\src\SampleEnclave - Copy\x64\Debug\App.pdb" /DYNAMICBASE "sgx_urts.lib" "kernel32.lib" "user32.lib" "gdi32.lib" "winspool.lib" "comdlg32.lib" "advapi32.lib" "shell32.lib" "ole32.lib" "oleaut32.lib" "uuid.lib" "odbc32.lib" "odbccp32.lib" /DEBUG /MACHINE:X64 /NODEFAULTLIB:"libcmtd.lib" /WX /INCREMENTAL /PGD:"C:\git\src\SampleEnclave - Copy\x64\Debug\App.pgd" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /ManifestFile:"x64\Debug\App.exe.intermediate.manifest" /ERRORREPORT:PROMPT /NOLOGO /LIBPATH:"C:\Program Files (x86)\Intel\IntelSGXSDK\\bin\x64\Debug" /TLBID:1
Sincerely,
Jesus G.
JesusG_Intel
Hello Edward,
Sincerely,
Jesus G.
