Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
1558 Discussions
Unsealing Process Does Not Return The Entire Input Data
Nazmus_S_
I am trying to seal a string, which contains about 7304857 characters. When I load the sealed data from disk to enclave and unseal it, I get only 1731 characters.
However, if I seal a shorter string (containing about 2000000 characters), it works fine.
Is there any limit on data size for a single seal operation?
Untrusted_Application.cpp
    uint32_t sealed_length = sizeof(sgx_sealed_data_t) + sizeof(input_case_char);
    char* sealed_data = (char*)malloc(sealed_length);
    seal_string(global_eid, input_case_char, sealed_data, strlen(input_case_char)+1, sealed_length);
    std::string sealed_file_path = "abc.dat";
    write_file((char*)sealed_file_path.c_str(), sealed_data, sealed_length);
    char* sealedBlob;
    sealedBlob = (char*)malloc(sealed_length);
    int* unsealed_length = new int[1];
    unsealed_length[0] = sizeof(input_case_char);
    long int length = load_file("abc.dat", sealedBlob);
    unseal_string(global_eid, sealedBlob, unsealed_length, sealed_length);
int write_file(char* path, char *data, int length)
    FILE *file = fopen(path, "w");
    int ret = fwrite(data, sizeof(char), length, file);
    if (ret != length)
        printf("write_file: Error %d\n", ret);
    fclose(file);
    return 0;
long int load_file(char* path, char *buf)
   long int length;
   FILE * f = fopen (path, "rb"); //was "rb"
   if (!f)
      return 1;
   fseek (f, 0, SEEK_END);
   length = ftell (f);
   fseek (f, 0, SEEK_SET);
   char *buffer = new char[length]();
   fread (buffer, sizeof(char), length, f);
   fclose (f);
   memcpy(buf, buffer, length);
   return length;
// load
 Enclave.cpp
void seal_string(char* input, char* output, int len_input, int len_output)
    char* data_to_seal = (char*)malloc(strlen(input) + 1);
    memcpy(data_to_seal, input, strlen(input) - 1);
    data_to_seal[strlen(input) - 1] = '\0';
    //Seal the data
    uint32_t sealed_len = sizeof(sgx_sealed_data_t) + sizeof(data_to_seal);
    printf("sealed length is %d \n", sealed_len);
    uint8_t *plain_text = NULL;
    uint32_t plain_text_length = 0;
    uint8_t *temp_sealed_buf = (uint8_t *)malloc(sealed_len);
    sgx_status_t ret = sgx_seal_data(plain_text_length, plain_text, sizeof(data_to_seal), (uint8_t *)&data_to_seal, sealed_len, (sgx_sealed_data_t *)temp_sealed_buf);
    if(ret != SGX_SUCCESS)
        //sgx_thread_mutex_unlock(&g_mutex);
        printf("Failed to seal data\n");
        free_allocated_memory(temp_sealed_buf);
        return;
    memcpy(output, (char*)temp_sealed_buf, sealed_len);
    free_allocated_memory(unsealed_data);
void unseal_string(char* blob, int* unsealed_length, int length)
    uint32_t* unsealed_data = 0;
    uint32_t unsealed_data_length = unsealed_length[0];
    char* blob_in_enc= (char*)malloc(length);
    memcpy(blob_in_enc, blob, length);
    sgx_status_t ret = sgx_unseal_data((sgx_sealed_data_t *)blob_in_enc, plain_text, &plain_text_length, (uint8_t *)&unsealed_data, &unsealed_data_length);
   if (ret == SGX_ERROR_INVALID_PARAMETER)
	printf("ENCLAVE: SGX_ERROR_INVALID_PARAMETER\n");
	return;
   if (ret == SGX_ERROR_INVALID_CPUSVN)
	printf("ENCLAVE: SGX_ERROR_INVALID_CPUSVN\n");
	return;
   if (ret == SGX_ERROR_INVALID_ISVSVN)
	printf("ENCLAVE: SGX_ERROR_INVALID_ISVSVN\n");
	return;
   if (ret == SGX_ERROR_MAC_MISMATCH)
	printf("ENCLAVE: SGX_ERROR_MAC_MISMATCH\n");
	return;
   if (ret == SGX_ERROR_OUT_OF_MEMORY)
	printf("ENCLAVE: SGX_ERROR_OUT_OF_MEMORY\n");
	return;
   if (ret == SGX_ERROR_UNEXPECTED)
	printf("ENCLAVE: SGX_ERROR_UNEXPECTED\n");
	return;
    printf("LOADED UNSEALED DAta  %s \n", (char*)unsealed_data);
    printf("\n \n \n ");
    printf("length of LOADED unsealed data %d \n", strlen((char*)unsealed_data));
EDL
public void seal_string([in, size=len_input] char* input, [out, size=len_output] char* output, int len_input, int len_output);
public void unseal_string([in, size=len_input] char* blob, [in] int* unsealed_length, int len_input);
you_w_
New Contributor III
Hi Nazmus S:
I think your you need a bigger heap size in enclave's configure file (eg: enclave.config.xml). You can try to adjust  <HeapMaxSize>0x100000</HeapMaxSize> to a bigger value. Then it will work. According to you data size I think it should be bigger than 0x6f7699. Maybe more.
you
Nazmus_S_
Hi You,
Thanks for your response.
I already have a much larger heap size, 0xD0000000.
Nazmus
