Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Unsupported C Standard Functions time() and gmtime()
kalsheraut
I realize the following is documented, I do however have a question none-the-less.
Unsupported C standard Functions
You cannot use the following Standard C functions within an enclave; otherwise, the compilation would fail.
Table 20 Unsupported C Standard Functions
time.h
Yes
timespec
clock(), mktime(), time(), asctime_s(), ctime(), ctime_s(), gmtime(), gtime_s(), localtime(), localtime_s()
I wish to load an existing library into an enclave with as few changes as possible. Unfortunately this library has a dependency on the c-standard library functions "time" and "gmtime". I have done the following:
<Enclave.cpp>
long time(long* arg)
	long retVal;
	if (ocall_time(&retVal, arg) != SGX_SUCCESS)
		abort();
	return retVal;
<Enclave.edl>
untrusted {
		[cdecl] long ocall_time([in] long* arg);
<App.c>
long ocall_time(long* arg)
	return (long) time((time_t*) arg);
That works ok for compiling (I have not yet been able to test run-time functionality as I need to also solve the gmtime call).
The issue I am facing with gmtime is that when I declare:
<Enclave.edl>
[cdecl] struct tm* ocall_gmtime([in] const long* timer);
Then the Enclave_t.h expects a tm** to be returned instead of a tm*. gmtime however returns a tm* so my ocall_gmtime would ideally be:
struct tm* ocall_gmtime(const long* timer)
    return gmtime((time_t*)timer);
What is the best solution for calling a c standard function that returns a pointer in this way?
Alternatively, is there a better solution for using "time()" and "gmtime()" in an enclave when they are necessary? Are there SGX alternatives that can be used instead?
Thanks and Regards,
- K
Hoang_N_Intel
Please take a look at the provided monotonic counter (https://software.intel.com/en-us/node/709160) and sgx trusted time (https://software.intel.com/en-us/node/709158) functions if the platform can support them.
