Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Using gcc 8.3 with c++14 or c++17 to compile enclave
shmoo
Although the documentation of the Linux Developer Refernence says that the enclave only works with the c++11 standard. I noticed that with gcc 8.3 it is possible to build the enclave in c++14 or c++17 mode.
Of course only as long as you don't use functionalities that are not allowed by the Intel SDK.
Why does this work? Is this allowed or can I introduce an unwanted bug?
JesusG_Intel
Hello Shmoo,
You are correct. As long as you use only the features allowed by the SGX SDK you should be okay. C++14 and C++17 are incremental improvements. Table 38 of the SGX Developer Reference for Linux lists the supported C++11 language features, which also apply to C++14 and C++17.
However, it is important to keep in mind that when a company says that a configuration is not supported, it means that the company has not tested or validated that configuration. It may or may not work. If it doesn't work, the company may not be able to help.
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello Shmoo,
Sincerely,
Jesus G.
shmoo
Thank you for your fast response!
JesusG_Intel
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
