Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Using sgx_tcrypto outside of enclave
magalhaes_duarte_cor
Is it possible to use the sgx_tcrypto library outside of an enclave?
If so which libraries need to be linked?
Manuel.
Zongmin_G_Intel
It is not supported. You should use openssl, standard IPP or other libs outside of enclave.
Zongmin_G_Intel
