Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Web Service Process is possible in SGX?
Sam5
How to call the web services from SGX. I want to call some web services from enclave. How to do? and what are the process is involved.
-Thanks
Surenthar_S_Intel
Hi Sam,
Implementing the whole web services infrastructure inside an enclave environment can be done but is not recommended due to large memory footprint. Developers should only be implementing the code and data that needs to be kept confidential, inside the enclave. For example, If you look in the remote attestation sample provided in IDZ portal, the client application implements the REST SDK in the untrusted part of the application and the payload to be communicated is generated inside the enclave
-Surenthar
Surenthar_S_Intel
Hi Sam,
-Surenthar
Sam5
Thanks for you detailed Information
