Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Where to find Ocp-Apim-Subscription-Key.
Martin__Claudia
I'm trying to find the Ocp-Apim-Subscription-Key to get the PCK certificate. According to https://api.portal.trustedservices.intel.com/documentation : "Subscription key which provides access to this API. Found in your Profile." so it should be on my profile but the webpage doesn't provide any of this information.
I am trying to achieve it from a Linux device if that makes any difference.
Thank you in advance.
EDIT: I have found that on the same link there is a Subscription link through which you have to sign in again. It's at api.portals/trustedservices.intel.com profile which provides the key, not software.intel.com as I thought.
JesusG_Intel
Hello Claudia, do you still need help with this issue? It sounds from your EDIT that you found the key.
Jesus
