Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Why Qemu-SGX not maintained any more?
LeoneChen
intel/qemu-sgx (github.com)
It say "This project has been identified as having known security escapes.", but what known security escapes?
Iffa_Intel
Yes, that is just to share you the concept of that attack in QEMU.
Focus on the fact that the vulnerability attacks host operating system that runs QEMU.
QEMU-SGX, as the name implies, it uses QEMU so even if Enclave don't trust OS&Host App in VM, or no VM, the vulnerability exist.
Cordially,
Iffa
Iffa_Intel
Generally, the QEMU is vulnerable to Virtual Machine Escape attack which triggered when fragment packets are reassembled for processing. This allows an attacker to perform arbitrary code execution at the same privilege level as QEMU itself, and completely crash the QEMU process.
Cordially,
Iffa
LeoneChen
Thanks for reply!
Any hyper-links or details about this vulnerability or news?
Iffa_Intel
Here it is (Note that this is public info):
1. Vulnerability in QEMU allows attackers to perform virtual machine escape
2. NVD for (no 1) vulnerability
3. KVM breakout
Hope this helps!
If you don't have any further inquiries, shall I close this case?
Cordially,
Iffa
LeoneChen
But it seems that Qemu escape will not influent security of Enclave in VM, since Enclave don't trust OS&Host App in VM
Iffa_Intel
Cordially,
Iffa
LeoneChen
Thanks!
Thus it's due to Qemu problem, not an SGX problem
Iffa_Intel
Glad that helps!
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
