Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Why SigRL Does Not Exist??
Loocar
GET https://api.trustedservices.intel.com/sgx/attestation/v4/sigrl/00000xxx
SPID, Product DEV Intel® Software Guard Extensions Attestation Service (Unlinkable) subscription key.
I get 200 but body is empty. Why?
How can i do?
Please help me, thx.
Daniel_ˢᵍˣ
"I get 200 but body is empty. Why?"
That's how it is supposed to be.
When you get status 200 OK there are two possible cases: SigRL exists or SigRL doesn't exist. If SigRL exists then the Base 64-encoded SigRL will be in body. If SigRL doesn't exist then the body will be empty.
It's written in Page 9 of the IAS spec (§§ 3.1.2-3):
https://api.trustedservices.intel.com/documents/sgx-attestation-api-spec.pdf
JesusG_Intel
Hello loocar,
If you are using the DEV environment you must access the environment with Base URL:
https://api.trustedservices.intel.com/sgx/dev
Your SigRL URL becomes: https://api.trustedservices.intel.com/sgx/dev/attestation/v4/sigrl/0000xxx
Sincerely,
Jesus G.
Intel Customer Support
Daniel_ˢᵍˣ
JesusG_Intel
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new
