Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
ccc-linux-guest-hardening
littleQ
I recently ran the fuzz program in ccc-linux-guest-hardeninghttps://github.com/intel/ccc-linux-guest-hardening .
I noticed in the ReadMe.md:
Patched Host Kernel: A modified Linux host kernel is used for TDX emulation and VM-based snapshot fuzzing. This setup does not run inside a VM or container!
What I want to know is where is the host kernel? Why can't it run in a VM or container?
Benny_Intel
Thank you for your question.
However, this forum is specifically focused on Intel SGX, and we do not provide support for Intel TDX and related projects here.
For your question, we recommend opening a GitHub issue in the corresponding GitHub repository.
Please note that the repository has been archived, so active support may no longer be available.
We appreciate your understanding.
littleQ
That is too bad for me. I found that I couldn't open an issue, and I noticed in the ReadMe.md:
Contact : [email protected]
What is this email address for? Will there be a reply if I send a message to it?
Benny_Intel
Please properly setup the email address you use in this forum.
Afterwards, a person from the the ccc repo will get in touch with you.
littleQ
