Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
dev IAS url return 401 code
Gradvis
I`we try to launch CDS for Signal Server hosted on SGX supported Azure VM.
I subscribe to DEV Intel® Software Guard Extensions Attestation Service (Unlinkable) and  get SPID  and PrimaryKey.
My config:
spid: D231E0...........................................44E918A
apiKey: 3432.......................................a8ff422de0aa
iasBaseUri: https://api.trustedservices.intel.com/sgx/dev
When i try to launch CDS i reseive error:
java.io.IOException: Failed to get signature revocation list (HTTP/401)
UPD:
{ "statusCode": 401, "message": "Access denied due to invalid subscription key. Make sure to provide a valid key for an active subscription." }
request: https://api.trustedservices.intel.com/sgx/attestation/v4/sigrl/00000c13 GETHeader: Ocp-Apim-Subscription-Key Value: 3432.......................................a8ff422de0aa
Subscription are in Active state. ApiKey Copy-Pasted
JesusG_Intel
Hello Gradvis,
Your post shows that you are sending your request to https://api.trustedservices.intel.com/sgx/attestation/v4/sigrl/00000c13. Try sending to the DEV environment at https://api.trustedservices.intel.com/sgx/dev/attestation/v4/sigrl/00000c13.
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello Gradvis,
Sincerely,
Jesus G.
Gradvis
Thank you!
It was a bug wich cut off "/dev" from URL in config.
JesusG_Intel
Hello Gradvis,
Thank you for confirming the solution worked for you.
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
Sincerely,
Jesus G.
