Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1546 Discussions
edger8r: Cannot import both "sgx_tprotected_fs.edl" and "sgx_tkey_exchange.edl"
AArya2
Consider the following enclave definition:
enclave
  from "sgx_tprotected_fs.edl" import *;
  from "sgx_tkey_exchange.edl" import *;
  trsuted
    public sgx_status_t dance_securely();
  untrusted
edger8r's output is an error message "detected circled import for `C:\Program Files (x86)\Intel\IntelSGXSDK\\include\sgx_tae_service.edl'"
Juan_d_Intel
As a temporary workaround, please comment out the line "from "sgx_tae_service.edl" import *;" from either sgx_tprotected_fs.edl or sgx_tkey_exchange.edl.
We're trying to find a solution to this issue.
Juan_d_Intel
AArya2
Thank you Juan.
To me it seems that edger8r does not mark already imported enclaves off, and that causes problems when the dependency trees of two imported enclaves coincide. The little extension that I have written for edger8r that I use for my own programs doesn't seem to have that problem.
Juan_d_Intel
Your assessment is correct.
You may submit a PR with your changes to the edger8r.
AArya2
But the Windows SDK is not open source, is it?
Juan_d_Intel
No, the Windows SDK is not open source. I thought you had modified the edger8r source code.
Could you post your extension here?
