Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
fTPM Endorsement Key invalid certificate
gerasiovM
pyca/cryptography can't parse the distributed EK certificate because it contains an encrypted default value for "critical" field in one of its extensions. This makes the certificate invalid and pyca/cryptography doesn't support parsing of invalid certificates.
Here's the github issue with relevant information:
https://github.com/pyca/cryptography/issues/12665
Attached is the PEM encoded EK certificate
Benny_Intel
Could you please elaborate what the relation of this request and Intel SGX is?
The Github Issue you linked to (https://github.com/pyca/cryptography/issues/12665) seems to be the proper place for the request and you already received an answer there.
Benny
