Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1545 Discussions
how can i do about the Problem with the local SSL certificate?Could not query IAS
bin__ch
I wan to run the offical remote attestation example(sgx-ra-example),but the server output is an error:
---- IAS sigrl HTTP Request ------------------------------------------------
HTTP GET https://test-as.sgx.trustedservices.intel.com/attestation/sgx/v3/sigrl/000013dc
* Could not resolve proxy: proxy-us.intel.com
* Closing connection 0
Could not query IAS
could not retrieve the sigrl
error processing msg1
Waiting for a client to connect...
another ra example output:
1546485734 INFO  : Received extended EPID group ID: 0
1546485734 INFO  : Serialization successful
1546485734 INFO  : Send to client
1546485734 INFO  : MSG1 received
1546485734 INFO  : Retrieving SigRL from IAS
1546485736 INFO  : curl_easy_perform() failed: Problem with the local SSL certificate
1546485736 INFO  :     Response status is: 0
1546485736 INFO  :     Content-Length: 0
1546485736 INFO  : Error, processing MSG1 failed
1546485736 INFO  : Close connection
1546485736 INFO  : Remote attestation done
I follow the offical course to get the local SSL certificate:
https://software.intel.com/en-us/articles/how-to-create-self-signed-certificates-for-use-with-intel-sgx-remote-attestation-using
my local SSL certificate  has been validated:
https://software.intel.com/en-us/articles/certificate-requirements-for-intel-attestation-services
I hope someone can give me some suggestions.
bin__ch
Configurations of the settings file to disable IAS proxy as the following:
//IAS_PROXY_URL=http://proxy-us.intel.com:911 //annotate this line to disable IAS proxy
and,
IAS_DISABLE_PROXY=1 //Set to non-zero to disable the use of a proxy server.
you should annotate the proxy, and other options was correct, this example will run well!
bin__ch
and,
bin__ch
and,
Marku__Enio
Hi bin, ch
I am running into the same problem as you and I have also disabled the line  IAS_PROXY_URL="http://proxy-us.intel.com:911"  by using ::
and SET IAS_DISABLE_PROXY=1
I still got the same message,
Have you probably changed this line SET RA_IAS_CLIENT_CERT_FILE="certificate.pem"
to the name of your self signed certificate?
Cheers,
Enio
