Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
index 1 in tdxtcbcomponents
UsamaS
In the "Get TDX TCB Info" flow (https://api.portal.trustedservices.intel.com/documentation#pcs-tcb-info-tdx-v4), step 4 states:
"For the selected TCB level verify that SVN at index 1 in tdxtcbcomponents array matches the value of SVN at index 1 in TEE TCB SVNs array (from TD Report in Quote). In case of a mismatch the selected TCB level should be rejected as TCB Info that was used for the comparison is not supported for this platform configuration."
My question is:
What is so special about index 1 that it requires an equality check? What does index 1 represent? Typically all SVNs have a non-equality check (>=) as in step 3 (a,b,c).
Peh_Intel
Hi UsamaS,
Let me check with the relevant team and get back to you at the earliest.
Peh
Peh_Intel
Hi UsamaS,
Thanks for your patience. I just received the updates as follow.
This index 1 SVN is the TDX Module major version. Originally, there was only 1 TDX 1.0 module, so the SVN had to match. Now that we have TDX 1.5 coming, it has a new major version, so the logic has to change, and those steps will also. The API doc will be updated soon to reflect this.
Peh
Peh_Intel
Hi UsamaS,
This thread will no longer be monitored since we have provided answer. If you need any additional information from Intel, please submit a new question.
Peh
