Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1545 Discussions
intel_sgx: the CPU is missing SGX;Error: Invalid SGX device.
desk
hello,
OS: Ubuntu* 18.04 LTS Desktop 64bits
Linux Header: linux-headers-5.4.0-42-generic
CPU: Intel(R) Core(TM) i7-10700 CPU
I reproduce the error in SampleEnclave, from the Intel SGX SDK sample code.
$ make SGX_MODE=HW
$ ./app
Info: Please make sure SGX module is enabled in the BIOS, and install SGX driver afterwards.
Enter a character before exit ...
The binary is runnable if SampleEnclave is compiled for simulation mode.
$ make SGX_MODE=SIM
$ ./app
Checksum(0x0x7ffca1fcc530, 100) = 0xfffd4143
Info: executing thread synchronization, please wait...
Info: SampleEnclave successfully returned.
lsmod |grep sgx
isgx 53248 0
dmesg | grep sgx
[ 2.033774] isgx: loading out-of-tree module taints kernel.
[ 2.033820] isgx: module verification failed: signature and/or required key missing - tainting kernel
[ 2.034035] intel_sgx: the CPU is missing SGX
I reinstalled the SGX SDK, PSW, and driver several times, and it didn't work.
I googled the error message but still couldn't find any viable solution.
Can anyone give me some hints to resolve this issue? I will be grateful for your help.
JesusG_Intel
Hello desk,
First, let's check your platform's support for SGX. Send the output from one of the these two options.
Option 1
On a Linux* system, execute cpuid in a terminal:
  1. Open a terminal and run$ cpuid | grep -i sgx
Option 2
Use test-sgx.c:
  1. Go to the SGX Hardware Github and download the file test-sgx.c or clone the repository
  2. Compile and run test-sgx.c according to these instructions:
  3. $ gcc test-sgx.c -o test-sgx
  4. $ ./test-sgx
Look for:
   SGX: Software Guard Extensions supported = true
   SGX_LC: SGX launch config supported   = false
  Software Guard Extensions (SGX) capability (0x12/0):
   SGX1 supported             = true
   SGX2 supported             = false
If SGX support looks good. Uninstall the SGX driver and re-install the latest version.
As root, run the command /opt/intel/sgxdriver/uninstall.sh.
Sincerely,
Jesus G.
Intel Customer Support
desk
I have enabled SGX in BIOS
ChrisB_Intel
Desk,
Please take a look at page 7 on the guide I have linked below. Please install the packages in the order they are listed, using the steps provided.
https://download.01.org/intel-sgx/sgx-linux/2.11/docs/Intel_SGX_Installation_Guide_Linux_2.11_Open_Source.pdf
If that doesn't resolve your issues please provide the list of all installed SGX components by running:
$ apt list --installed | grep -i sgx
Chris
desk
hello Chris,
I've used the steps listed to install, but I still can't.
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libsgx-ae-epid/unknown,now 2.13.103.1-bionic1 amd64 [installed,automatic]
libsgx-ae-le/unknown,now 2.13.103.1-bionic1 amd64 [installed,automatic]
libsgx-ae-pce/unknown,now 2.13.103.1-bionic1 amd64 [installed,automatic]
libsgx-ae-qe3/unknown,now 1.10.103.1-bionic1 amd64 [installed,automatic]
libsgx-aesm-ecdsa-plugin/unknown,now 2.13.103.1-bionic1 amd64 [installed,automatic]
libsgx-aesm-epid-plugin/unknown,now 2.13.103.1-bionic1 amd64 [installed,automatic]
libsgx-aesm-launch-plugin/unknown,now 2.13.103.1-bionic1 amd64 [installed,automatic]
libsgx-aesm-pce-plugin/unknown,now 2.13.103.1-bionic1 amd64 [installed,automatic]
libsgx-aesm-quote-ex-plugin/unknown,now 2.13.103.1-bionic1 amd64 [installed,automatic]
libsgx-enclave-common/unknown,now 2.13.103.1-bionic1 amd64 [installed,automatic]
libsgx-epid/unknown,now 2.13.103.1-bionic1 amd64 [installed]
libsgx-launch/unknown,now 2.13.103.1-bionic1 amd64 [installed]
libsgx-pce-logic/unknown,now 1.10.103.1-bionic1 amd64 [installed,automatic]
libsgx-qe3-logic/unknown,now 1.10.103.1-bionic1 amd64 [installed,automatic]
libsgx-quote-ex/unknown,now 2.13.103.1-bionic1 amd64 [installed]
libsgx-urts/unknown,now 2.13.103.1-bionic1 amd64 [installed]
sgx-aesm-service/unknown,now 2.13.103.1-bionic1 amd64 [installed,automatic]
desk
hello Chris,
Will it be available in windows, but not in Ubuntu on VMware Workstation pro?
desk
hello,
I ran the command on this website:https://github.com/intel/sgx-software-enable
sudo ./sgx_enable
This CPU does not support Intel SGX
I feel very strange.
JesusG_Intel
Hello desk,
Option 1
Option 2
Use test-sgx.c:
  4. $ ./test-sgx
Look for:
Sincerely,
Jesus G.
JesusG_Intel
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
