Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
multiple enclaves in a single application
Gokhale__Sushant
How to create multiple enclaves in a single application?
Sample code(or link to it ) would be better. Need it for my academic project.
Scott_R_Intel
Hi Sushant.
The only thing you really need to do to load multiple enclaves is to make sure they are named differently.  The LocalAttestation sample actually loads up 3 different enclaves (simply named Enclave1, Enclave2, and Enclave3).
https://github.com/intel/linux-sgx/tree/master/SampleCode/LocalAttestation
Hope this helps.
Scott
Scott_R_Intel
Hi Sushant.
Hope this helps.
Scott
Gokhale__Sushant
Thanks. And how do you generate "Enclave1_private.pem" file for each enclave?
Scott_R_Intel
You can use OpenSSL to generate the keys you need.  See the "Enclave Signing Tool" section of the latest SGX Dev Ref for Linux for examples of how to do so:
https://download.01.org/intel-sgx/linux-2.4/docs/Intel_SGX_Developer_Reference_Linux_2.4_Open_Source.pdf
But, just as an FYI, unless you want/plan to whitelist each enclave signing key separately, you probably want to use the same signing key for all your enclaves.
Regards.
Scott
