Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
sgx-dcap-pccs package not found
alche
Hi, I'm trying to install SGX SW using this guide https://download.01.org/intel-sgx/latest/linux-latest/docs/Intel_SGX_SW_Installation_Guide_for_Linux.pdf
Appendix 2, step 2, sgx-dcap-pccs installation
sudo apt-get install sgx-dcap-pccs
returns error
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following NEW packages will be installed:
sgx-dcap-pccs
0 upgraded, 1 newly installed, 0 to remove and 35 not upgraded.
Need to get 1188 kB of archives.
After this operation, 3715 kB of additional disk space will be used.
Err:1 https://download.01.org/intel-sgx/sgx_repo/ubuntu jammy/main amd64 sgx-dcap-pccs amd64 1.23.100.0-jammy1
404 Not Found [IP: 2600:1406:5400:2a0::a87 443]
E: Failed to fetch https://download.01.org/intel-sgx/sgx_repo/ubuntu/pool/main/s/sgx-dcap-pccs/sgx-dcap-pccs_1.23.100.0-jammy1_amd64.deb 404 Not Found [IP: 2600:1406:5400:2a0::a87 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Benny_Intel
The issues should be fixed now.
@manuelgustavo Thank you very much for the quick feedback on Ubuntu 24.04.
@alche Can you confirm that the installation also works for you on Ubuntu 22.04?
Benny
manuelgustavo
The same happens for ubuntu 24.04!
Benny_Intel
thank you very much for reporting the issue. We are working on it and it should be fixed soon.
Benny
manuelgustavo
For Ubuntu 24.04 it seems fine now!
Thanks!
Benny_Intel
Benny
alche
Seems to work now, thank you!
