Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
user_check protection for SGXSpectre
Elephant
Intel has released a technical advisory about the fixes for Spectre.  However, I would like to get more insight on how to handle user_check.  So from the "Intel® Software Guard Extensions (SGX) SW Development Guidance for Potential Bounds Check Bypass (CVE-2017-5753) Side Channel Exploits" whitepaper, Intel mentioned that we have to protect user_check inputs with the following pattern:
uint32_t enclave_function(const uint8_t* user_check_input,
uint32_t user_check_size)
// make sure input buffer is outside enclave
int SGXAPI sgx_is_outside_enclave(const void *addr, size_t
size);
if (!sgx_is_outside_enclave(user_check_input,
user_check_size)) {
// error code
else {
_mm_lfence();
However, how do I protect the structure that I passed with user_check when it has multiple pointers inside?
Thanks!
Kind Regards,
Elephant
Hoang_N_Intel
If the buffer is a structure of multiple pointers to other buffers, you will probably have to add one call to sgx_is_outside_enclave per pointer before you reference it.
