Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1546 Discussions
where can find the code about creating the quote in the sample code in the SDK?
yu_b_1
Hi.In the sample code RemoteAttestation directory, I couldn't find the source code about creating the quote.
I think some api ,such as  sgx_init_quote,sgx_create_report, sgx_get_quote etc  should be used , but I can't find it in the file .
who can tell me the file name including those codes?
the url of the code :https://github.com/01org/linux-sgx/blob/master/SampleCode/RemoteAttestation
Thanks a lot.
you_w_
New Contributor III
Hi yu b:
When you call "sgx_ra_proc_msg2", what's happened?You can find what you want I     "[-] ukey_exchange.cpp" and    "[-] tkey_exchange.cpp".
you
you_w_
New Contributor III
Hi yu b:
you
yu_b_1
Yes. you are right, I find it.
you_w_
New Contributor III
Hi yu b:
Actually in hardware mode, PSW's QE(quoting enclave) helps to generate the "quote". The file "linux-sgx\psw\ae\qe\quoting_enclave.cpp" shows the  implement. You can look into it.
you
